csp Posted June 9, 2013 Share Posted June 9, 2013 (edited) I have a surface where points have been scattered uniformly and I would like to distribute the pscale in a random function but the sum of them will not overcome the area of the surface including a gap between them. (pscale_sum + gap) <= area_sum [/CODE] Any ideas? Edited June 9, 2013 by cparliaros Quote Link to comment Share on other sites More sharing options...
kleer001 Posted June 10, 2013 Share Posted June 10, 2013 Interesting problem. What's the effect you're going to use it for? My first impulse is to use those points and create a voronoi break up of the surface then use the pieces to control the pscale. What's probably easier is to use the scatter's compute nearest 2 neighbors and then divide that by 2 for the pscale. Quote Link to comment Share on other sites More sharing options...
