MrGAG Posted June 10, 2013 Share Posted June 10, 2013 Hello, I am having a problem with some flipping rotations when I copy geometry on some deforming points. No matter where the normal vector is pointing, it seems I can't avoid the problem. I attached my hip file. hoping someone can point me in the right direction lsystem_test_01.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
sanostol Posted June 11, 2013 Share Posted June 11, 2013 (edited) does this work for you? lsystem_test_02.hipncFetching info... Edited June 11, 2013 by sanostol Quote Link to comment Share on other sites More sharing options...
MrGAG Posted June 11, 2013 Author Share Posted June 11, 2013 Hi, thank you for answering. it seems to be a little better, but can still see some strange rotations on severals circles. And I must admit I don't fully understand what you did with these vops. I never played with quaternions. They scare me a little ! But I really would like to find a solution to this recuring problem I have. and quaternions might be the right answer, as scary as they may be ^^ thank again Quote Link to comment Share on other sites More sharing options...
sanostol Posted June 11, 2013 Share Posted June 11, 2013 (edited) if you want non flipping rotations quaternions are a good way, they might be complex in theory, but in cg they are most of the times quite easy to use i just get the orient quaternion attribute from the wiresim, ( you even get the twist) and transfer it to the leaves with a id, so every leave knows where it came from. now You convert You original orientation represented by up and N to a quaternion and multiply them quaternion multiplication means adding rotations and write it back. the copy picks up the orient attribute EDIT: try the new file, the normal got updated by the deform and made the rotation going wrong, by storing the orientation as quaternion in the beginning it works better now lsystem_test_03.hipncFetching info... Edited June 11, 2013 by sanostol Quote Link to comment Share on other sites More sharing options...
MrGAG Posted June 13, 2013 Author Share Posted June 13, 2013 Hi, Yes indeed, it works better now . I am still a little confused by quaternions, but I guess I'll have to play around with them to get more confortable with their use. Anyway, thanks a LOT for your help Quote Link to comment Share on other sites More sharing options...
