displacement shader problem on fractured object
muzaffer
Hi there
hoping someone on here could help me out for annoying problem. I have fractured objects with voronoi fracture and added displacement shader. I found a problem after renders done.
Problem is displacement texture is not stable and slightly jumping/sliding around every frame after fractured.
I added here houdini file.
thanks for help
rocktextureTest.hipnc
You need to add a restSop. Left side is your normal geo, right is a still frame of the geo (so add a timeshift node,remove the $F and set a frame number).
The shader might already be setup to look for a rest frame, if not you need to add a restSHOP in the shader, then it will use the point position from the rest instead of the moving points.
Thanks for replying me Christian,
I have done what you explain to me in geoSop level, just add timeshift node to restposition node and linked to right side
but still problem is there I might made a mistake, also I have resp pos node is shader network,
could you make simple network for me to see it what I am doing wrong.
thank you very much
