Flip Fluid's surface is not smooth...
daehuck
post-9685-0-51735900-1371625453_thumb.pn
Hi, I made a flip fluid which is collide with glass
everything looks fine, but there is a one problem.
As you can see in image Fluid's collision surface is not smooth.
I think it is related with particle seperation and collision division size
But, I changed options but it looks same.
My particle seperation setting is 0.3 very low.
Is there any solutions for this problem??
ANY COMMENT IS HELPFUL FOR ME.
Edited by daehuck
0.3 isn't very low.
In the particle fluid mesher turn on filtering (last tab) and mess around a bit with the settings.
Also you can append a smoothSop and filter the geo. Stick the first field up somewhere between 2 and 6, there's funky stuff that happens between 1 and 2..
0.3 isn't very low.
I made with a flip fluid. So, I can't controll particle fluid surface's options.
Is there any solution to adjust the Flip's particle fluid surface option?
