How to calculate 2D normal (base on Camera Coord Space)?
In vopsop I have a constant node which is linked to the position of my camera, and I make a subtract from camera to each point position (the points are from my fluid surface), but I can not for sure whether my way is correct or not. I just need normal from camera space not world coordinate.
post-9044-0-18033600-1371626531_thumb.jp
post-9044-0-13924000-1371626535_thumb.jp
normal_in_camera_space.hipnc
Edited by yjcnbnbnb200
believe it or not N in shader is already in camera space, no alteration in SOPs is necessary so you can remove your vopsops and just add N to your export image planes
for cases where you actually need N or other attribute in world or object space you can Transform VOP in shader to convert from camera space to other, but not for your case
Oh, I remember that transform node, thank you very much.
