ssimoneaux Posted June 20, 2013 Share Posted June 20, 2013 Hello, I'm using Houdini 12.5, and am going through some pyro tutorials for a while back. It looks like in earlier versions of Houdini, the pyro shelf tools created a low res pyro and upres pyro node automatically, while in the current version this has changed to an import_pyro_build node. My question is, with this new setup, once the simulation is exported from the import_pyrofields node, is adding in an upres node still necessary? Any explanations or pointing to previous posts that discuss this would be greatly appreciated. I'm pretty new to Houdini, and am still learning the ins and outs of the program, thus the confusion. Thanks, Quote Link to comment Share on other sites More sharing options...
bunker Posted June 20, 2013 Share Posted June 20, 2013 (edited) You can still upres your sim with the upres shelf button but since Pyro2 is faster and better at managing memory the upres stage has been removed by defaut. It all depends on how much time and memory you have, for most situations I would say you can get the same details faster while using less RAM when going through lowres+upres, as long as you know how to map the noise properly - it's not a magic one button solution Edited June 20, 2013 by bunker Quote Link to comment Share on other sites More sharing options...
ssimoneaux Posted June 20, 2013 Author Share Posted June 20, 2013 Thanks for the additional information. It helps. I doubt I know how to map noise properly at this point, but will no doubt learn eventually. Quote Link to comment Share on other sites More sharing options...
