rurik Posted June 22, 2013 Share Posted June 22, 2013 Hello Probably a very basic question...but I have a bunch of points coming in from a 3d capture/photogrammetry process... I'd like to shade the points, without having to copy geometry onto them...I tried making particles out of them, and used a basic clay shader...but no luck. Any recommendations? Do I have to create geometry? Thanks Quote Link to comment Share on other sites More sharing options...
rurik Posted June 22, 2013 Author Share Posted June 22, 2013 Actually let me update my question... I have a texture I want to apply to my points, but knowing that the points cannot be "shaded", can I take the average color of my texture at each point and apply that color to the points? Hopefully this makes sense... Quote Link to comment Share on other sites More sharing options...
0rr Posted June 22, 2013 Share Posted June 22, 2013 Hello Probably a very basic question...but I have a bunch of points coming in from a 3d capture/photogrammetry process... I'd like to shade the points, without having to copy geometry onto them...I tried making particles out of them, and used a basic clay shader...but no luck. Any recommendations? Do I have to create geometry? Thanks Are you talking about viewport shading here? If so then for simple shading all you need are normals. So how about calculating the gradient from a sdf of your points and then just color the points. See this simple example. simple.hip Quote Link to comment Share on other sites More sharing options...
rurik Posted June 24, 2013 Author Share Posted June 24, 2013 Hmm, not sure I understand your approach... What I have is a piece of geometry with UV coords and a texture properly mapped to it. What I would like to achieve is to scatter points on this geometry and transfer the color attribs of the texture to the points... I think the solution might be quite simple and explained here http://www.sidefx.com/index.php?option=com_content&task=view&id=1423&Itemid=132 But I'm very curious about your approach, which seems really interesting. I'll play around with the hip file, thanks a lot for sending. Quote Link to comment Share on other sites More sharing options...
anim Posted June 24, 2013 Share Posted June 24, 2013 ... What I have is a piece of geometry with UV coords and a texture properly mapped to it. What I would like to achieve is to scatter points on this geometry and transfer the color attribs of the texture to the points... you can just use AttribFromMap SOP to get color information from texture to your points based on UV attribute you can as well create pscale attribute to control size of the points while shaded if you have N on the points then you can even tell mantra to orient points based on N instead of looking towards camera by checking Use N For Rendering in your object in Render/Geometry Tab Quote Link to comment Share on other sites More sharing options...
