What does feedback, impact, relationship mean in SOP Solver?
dop_geometry - is geometry data of processed object (based on Data Name on SOP Solver)
impacts - imports impact data from processed object as points with various impact info as attributes
feedbacks - imports feedback data from processed object (similar to impacts but usually from object interaction with fluids)
both impact points and feedback points you can use to modify dop_geometry, the resulting geometry will be sent for further processing in this and/or next timestep
relationship_geometry - imports relationship geometry, like glue network constraint (if the SOP solver is used as a constraint solver ), so you can delete or add links to affect constraints
Thank you for your detail description, very helpful!
