Houdini Performance
post-9983-0-25340700-1372633976_thumb.pn
I am simulating a lot of particles. Why is Houdini not using all threads to the full extent. Is this normal, is this as much multi-threading as I can get out of houdini. I have 4 real threads and its not even using one of them fully (which would be 25%).
Just wondering.
try to rebuild all pop nodes with vopPops they are multihreaded, there are still some nodes that You can't really avoid by that way, but it speeds up things
EDIT: in 12.5 many vexfunctions where improved and have better threading. for example the intersect, primattrib and xyzdistance are very fast now. it might be a bit more work at the beginning
Edited by sanostol
