Image per primitive
Ezz
Hi good folks!!
I am playing with Python(expression) i Houdini and I am allready stuck with some syntax-problems.
What I want is to assign a primitiveattribute(string) called "map" with this Hscript-expression like this:
$HIP\pic\butterfly`$PR % 7+1`.pic
but i Python. My goal is to point at a folder, on my harddrive, with random jpg`s(or like) and let the expression figure the rest out.
What I have so fare is:
import os
file = os.filepath("U:erik/pictures")
texturepath = file[primitivenumber] - Here I am stucked!!
return texturepath
Is there a method to this like the above descriped Hscript??
Thank you very much!!
Erik
Hi Thomas
Thank you for guiding me in the right direction. Here is the expression so far:
import os
thepath = os.listdir("U:/martin/awesome 3d stuff/")
mod = len(thepath)
primnum = int(lvar("PR"))
myimagenumber = primnum % mod
tex = ("U:/martin/awesome 3d stuff/" + thepath[myimagenumber])
return tex
Next step is to make a variable from a nulls file-parameter, so that I dont have to write the images path in the expression. Just to make it easier to point at the files.
Thanks again :-)
Erik
Hi.
Here is a file with two ways of fetching files via Python.
My next goal is to put several imagesequences in the same folder and have different sequences pr primitive.
I miss a smart Python-trick to isolate the different filenames in a list.
Let say I have 300 frames in one list called [ fileA.0000.jpg -> fileA.0099.jpg, fileB.0000.jpg -> fileB.0099.jpg, fileC.0000.jpg -> fileC.0099.jpg ]
How can I make a new list containing only containing [ fileA, fileB, fileC ] ??
Cheers Erik
fileOnPrim_v002.hipnc
