OTL with multi Output
Hi everyone,
I am currently working on a OTL that needs to have 3 outputs, but I can't find a tap to add them.
I went through the help and it says that in the Operator Type Properties under the input/output tap should be an option.
But I am only seeing inputs and no tap/section for outputs.
Any idea where I can add extra outputs?
Cheers,
Juri
PS: This is in H12.5.427
If you have more than one possible output of your tool you would want to implement a menu on your tool to choose which output the user wants. Otherwise just merge all outputs together at the end?
thats the way it works at the moment.
working with multiple output groups, so that they can be separated afterwards.
I was just checking since the documentation states clearly that there is a possibility to add outputs and name them..... but no option in the Operator Type Properties.
  • 3 years later...
