Making pop up UIs in Houdini
Hi guys,
Does Houdini come with any way of making reasonably sophisticated/complex UIs that are more advanced than just a simple "hou.ui.displaymessage()"?
Lets say I want to click a shelf button and get a pop up window that allows me to enter a few strings, choose from a couple of drop down menus and tick a couple of checkboxes.
I want to use the results of whatever the user picks to run some more code.
Is this kind of thing possible? I can't find anywhere in the "hou" reference that shows this can be done...
Thanks
So far I have found a few things like:
hou.ui.readMultiInput("This is a message", ["test1", "test2"])
hou.ui.selectFromList(["1","2","3"])
But it doesn't seem like you can combine them and it seems a bit limited in the types of ui elements available.
Is PyQT the only way?
If you can get your head around Houdini's .ui script you can make some not too complex dialogs with the look and feel of Houdini. It's a bit weird though and not super full featured.
I'd say PyQt is probably the best bet.
I'm partial to the .ui scripting language though. It's basically like a cleaner version of Mozilla's XUL. To use it, you need to create a dialog.ui file and give it the full path to hou.ui.createDialog(). This creates a hou.Dialog object that you can then do stuff with.
Unfortunately, there's no documentation for it though. The closest is the HDK documentation:
http://www.sidefx.co...k_uinative.html
http://www.sidefx.co...e_uiscript.html
http://www.sidefx.com/docs/hdk12.5/cmd__ui_8_c.html
http://www.sidefx.co...8_c_source.html
