Problem controlling fracture
iwilson2
Hey guys!
So I'm working on a shot for my reel but i'm having trouble controlling the fractures for this. If you look in the file, visual the fractures in the voronoi fracture node- thats the way I would like to fracture the geometry. I would like the smaller pieces to explode outwards and have the large upper half fall to the ground before it collapses again. The issue I'm having is that when I make the object breakable and copy all of the parameters from the voronoi points and voronoi fracture nodes to the fracture parm node, the geometry still doesn't fracture the same. Can someone explain what I'm doing wrong or missing?
Thanks!
buildingFracture_v007.hipnc
