Is there a way to navigate where a parameter is located inside a shade
I'm not sure if there is a direct way but when you look at Edit Parameter Interface on the VOP network you can see relative path to each Parameter VOP node just by clicking on parameter (it's displayed at the top, just below red warning that the changes are live)
then just go into that level and use Find Node (Ctrl+F) to find it by name
