Hudson Posted July 29, 2013 Share Posted July 29, 2013 (edited) Hi, I am trying to create a VDB set-up to immitate the "volume from attribute-sop". In my test scene I am trying to apply a vel field to a flip simulation. Using a volume from attribute set-up everything works fine. But If I use the VDB-setup instead an odd "curl-noise" is added to the vel-field. Take a look at the hip-file. I am probably doing something wrong. Thank you in advance! Edited July 29, 2013 by Hudson Quote Link to comment Share on other sites More sharing options...
Hudson Posted July 29, 2013 Author Share Posted July 29, 2013 (edited) Oh, my collegue solved it... Just needed a "convert vbd" sop after the "vdb from polygons" sop and also in "the vector field from sop" in dops the "border type" should be constant. dumb me VDB_instead_of_Vol_from_attr.hipnc Edited July 29, 2013 by Hudson Quote Link to comment Share on other sites More sharing options...
