Controlling a keyframe via input field
Hello,
Is it possible to be able to control the placement of a keyframe via a input field without scripting? ( sad to say script guru, i am most definitely, not ).
To elaborate :
i have a digital asset that has 3 keyframes.
The first keyframe is fine; is always supposed to be at 0, with a value of 1.
The second keyframe is supposed to always be in the middle of the 3 keyframes, with a value of 0.
The third keyframe is the one that i would want the user, in a Digital Asset, to be able to input in, which frame does he/she want the keyframe to be at, always with a value of 1.
To make things slightly more complicated, this one input is currently now controlling two other nodes, which is already working fine, because i know how to Paste Copied Relative References, tweak a bit of the expressions,etc.
Its just this part that im not so sure about; how to hook up this input field to be able to control the third keyframe.
Or does it have to be via scripting?
would appreciate any input.
I've thought of that too, using a ramp parameter. The problem is how would i be able to hook up the value of that position parameter input field, with the keyframe in the blendshape node that i've animated..
Could you elaborate please?
