HOW TO CRACK WITH L-SYSTEM?
daehuck
Hi, guys im trying to crack with l-system.
As a matter of fact, I think almost done. but there is a one problem.
I made a l-system and make it polygon and subtract it with box.
and make a simple vopsop to add some noise.
So, i made a cookie node and set A is BOX and B is l-system polygon. and choose A-B
And problem is like this
check below image.
and i add my hip file.
So, please help me:)
post-9685-0-79543600-1375679868_thumb.jp
20130805_Lsystem.hip
Hey,
Your problem (if I understood correctly) seems to come from the noise itself.
You're setting it to the position of the points, which is changing.
Here's a version where the noise is only using the Y position and an ID set on each points.
Hope that corrects your problem.
Cheers,
Remi
P.S : You should clean your files before sending it.
20130805_Lsystem_corrected.hipnc
Hey,
Cheers,
Remi
First, Thanks for your kindness.
And Im sorry for my node's chaos situation.
I should have cleaned up all unused nodes.
