WaldoB Posted August 9, 2013 Share Posted August 9, 2013 (edited) I've just started using Houdini, and I'm stuck in the middle of a tutorial. I have a nurbs path with two groups going into fuse node. This is what the fuse node looks like: This is the join node and its preview: Wrap Last to First and Only Connected is checked. In the tutorial the primitives stay in the group, but in my version they don't. I'm assuming the inner workings of the fuse node have changed since 2009? Thanks! Waldo Edit: So the question is: Is this behaviour normal? Is there a node I should use instead of Join? Edited August 10, 2013 by wbronchart Quote Link to comment Share on other sites More sharing options...
yongbin Posted August 13, 2013 Share Posted August 13, 2013 I think it's normal behavior, because it's a primitive group and their primitives have merged with join sop. So they can't look their original pirivimives. Quote Link to comment Share on other sites More sharing options...
WaldoB Posted August 20, 2013 Author Share Posted August 20, 2013 This is correct. It was just newbie confusion Quote Link to comment Share on other sites More sharing options...
