Why am I getting constraint has a bad object reference warnings?
I am following a tutorial doing it exactly, but Houdini is giving me errors. I opened the provided hip file but even that doesn't open correctly, i.e. many missing parameters, one of which was the Goal Points parameter in the SBD Pin Constraint, so the new Goal Points parameter show up empty. I think it was created using Houdini 11.
Here is a pic showing it:
Am I missing something?
Edited by magneto
  • 6 months later...
Cloth has undergone some changes since then. I think you might need to recreate the Cloth/constraint nodes. Also check the Operator Type Manager that you are not using any old definitions that were Embedded in your .hip.
