FR3D Posted August 21, 2013 Share Posted August 21, 2013 (edited) i am retiming as pyro BGEO sequence, everything works fine. The problem i am having is when i do the volume mix, it looses @name=heat @name=temp @name density resulting in just smoke when i render. I tried attribute tranfer and many other node and i couldnt figure it out how to promote those attribute in my retimed pyro Edited August 21, 2013 by FR3D Quote Link to comment Share on other sites More sharing options...
FR3D Posted August 21, 2013 Author Share Posted August 21, 2013 (edited) ok i found how to transfer the heat temp and density to the volume i transfered each field by itself Now the problem is that no matter what, the retime actually kills those attributes and the render is just smoke Edited August 21, 2013 by FR3D Quote Link to comment Share on other sites More sharing options...
