kidsreturnjj Posted August 22, 2013 Share Posted August 22, 2013 (edited) I'm testing change color of tube at this direction with using PointCloud for adjusting it into complex geometry later. But white and black part value are stuck. Could you give me some advice about this file? I attach the file. Pointcloud_Burning.hipnc Edited August 22, 2013 by kidsreturnjj Quote Link to comment Share on other sites More sharing options...
Annon Posted August 22, 2013 Share Posted August 22, 2013 I had a quick look. You weren't looking up anything in the pointcloud, it was set to default. And I'm not exactly sure what you were trying to achieve. So i've just done a quick solver thing where the heat source moves up the tube and transfers heat and added a bit of cooling. you could remove or reduce this as you prefer. Hopefully that'll help a bit. Pointcloud_Burning.hipnc 1 Quote Link to comment Share on other sites More sharing options...
kidsreturnjj Posted August 23, 2013 Author Share Posted August 23, 2013 Thanks so much ChiristianW. You example file works as what I want to do !! Really appreciate for your help and file One thing what I want to ask you is that, you put key on point what is source of point cloud texture. Is there any way to do same effect with While loop without Keyanimation? Could you give some advices? Quote Link to comment Share on other sites More sharing options...
Annon Posted August 23, 2013 Share Posted August 23, 2013 I'm not sure exactly what you mean by "you put key on point what is source of point cloud texture". But no you can't do it in forloop, you need a progressive sim, forloop just works on current frame only. Quote Link to comment Share on other sites More sharing options...
kidsreturnjj Posted August 26, 2013 Author Share Posted August 26, 2013 Thanks for your response. I talked about your use channel Editor Y-axis graph.(going up) It makes point cloud source points move. What I want to do effect is bellow picture. This is snap shot of PeterQuint tutorial. He used neighbor node in Vex, and he change attribute value through neighbor node, but neighbor node just can be use in single geometry. I would like to adjust this effect into multiple geometry as bellow picture. So, I try to change attribute value for multiple geometry. If pointcloud is not suitable this effect, what is good way to approach to this effect? Quote Link to comment Share on other sites More sharing options...
