kidsreturnjj Posted August 26, 2013 Share Posted August 26, 2013 I saw, Bind Node can export Attribute and import Attribute in Vex. It seems same function as Parameter Node (export Attr)and Import Attribute Node in Vex What is different between these? Could you give me some advice? 1.When export Attribute : Bind vs Parameter? 2.When import Attirubte : Bind vs Import Attribute? Quote Link to comment Share on other sites More sharing options...
magneto Posted August 26, 2013 Share Posted August 26, 2013 This might be useful: http://forums.odforce.net/index.php?/topic/17701-is-bind-export-vop-faster-to-use-than-add-attrib-vop/ 1 Quote Link to comment Share on other sites More sharing options...
kidsreturnjj Posted August 26, 2013 Author Share Posted August 26, 2013 Thank Magneto. It is so helpful to understand what I want to ask I would like to ask you one more thing. Old school said, Import Attribute VOP or Get attribute VOP are preferred than Bind VOP when fetching data is dynamic. But in same time, Import Attribute VOP is only available in SOP, not as Volume VOPSOP. Isn't Volume VOPSOP kind of Dynamic? Quote Link to comment Share on other sites More sharing options...
magneto Posted August 26, 2013 Share Posted August 26, 2013 No Volume VOP is not dynamic. oldschool means that the data is not static, not DOPs if that's what you thought 1 Quote Link to comment Share on other sites More sharing options...
kidsreturnjj Posted August 26, 2013 Author Share Posted August 26, 2013 Thanks you so much to make sure!! !! Quote Link to comment Share on other sites More sharing options...
