Ali Haider Posted September 14, 2013 Share Posted September 14, 2013 (edited) Hello i am doing a fluid sim which is 400x100x800 around 81,361,150 particles , when i wanted to see its mesh it gives me an error and crashed, i wanted to tweak and render my ocean geometry for render but getting this stopping me from doing that. My PC Config is Intel i7 3770K (8 CPUs)3.5GHz 32 Gb Ram GTX 570 HD 4049MB Windows 7 Ultimate Houdini 12.5.469 i am in the middle of somewhere any help would be highly appreciated. Error is " The Nvidia OpenGL driver lost connection with display driver and is unable to continue. The application must close. Edited September 14, 2013 by Ali Rizvi Quote Link to comment Share on other sites More sharing options...
malexander Posted September 14, 2013 Share Posted September 14, 2013 The resulting mesh may be too large for the card to handle. Since you're on Windows, the driver time limited recovery will reset the driver after 2s of the driver not responding, which looks like the case here. Try setting the cook mode to Manual and inspect the mesh size with MMB info. If it's too large (10's of millions of quads), adjust the surfacing parms to make a smaller mesh. You can also change the Windows time limited recovery to a longer interval to avoid the driver reset. See the link here: http://msdn.microsoft.com/en-us/library/windows/hardware/ff569918(v=vs.85).aspx H13 has better support for extremely large meshes which will avoid the driver reset. Quote Link to comment Share on other sites More sharing options...
Ali Haider Posted September 16, 2013 Author Share Posted September 16, 2013 (edited) thanks mark above mentioned link is broken or changed.. ll give it a try with surface parms hope it ll work Edited September 16, 2013 by Ali Rizvi Quote Link to comment Share on other sites More sharing options...
malexander Posted September 16, 2013 Share Posted September 16, 2013 It looks like the forum cut it off at the second ). Just add ) at the end of the URL and it should work. ie: msdn.microsoft.com/en-us/library/windows/hardware/ff569918(v=vs.85) Quote Link to comment Share on other sites More sharing options...
Ali Haider Posted September 18, 2013 Author Share Posted September 18, 2013 oops ... thanks mark Quote Link to comment Share on other sites More sharing options...
