Smoke Details
Naeem
Hi all,
I am working on a shot where the camera has to go through a huge wall of smoke. I was looking for some tips on how to get a good amount of detail in the smoke while keeping the cache size and render times reasonable. My smoke container is 30x20x15 and with a division size of 0.05 I am not really getting enough detail - I tried going as low as 0.03 but then the cache size is getting out of hand. I have disabled all the unnecessary fields on the DOP Import to keep my cache size to a minimum. See attached screenshots to see how the smoke looks just as the camera is about to go through it.
For the render I am using PBR with Blackman volume filter with filter width set to 1.25 and Shading Quality Multiplier set to 2, Pixel Samples set to 8x8, Volume Quality at 0.25, Volume Shadow Quality at 0.5 and Transparent Samples at 16. Anything else I can do to improve the render?
post-7633-0-10363500-1379336674_thumb.jp
post-7633-0-89709500-1379336939_thumb.jp
Edited by Naeem
How large are the cache sizes and how long the render times? Detail takes both!
A few things to try; smoke clusters shelf tool, manually changing the resize_container size to the frustum you can see, using an Uprez container cropped for the part you are flying through and mix it in compositing with a low res.
Thanks - I will try to go through it later, in the mean time would a LOD box setup work where you would fly through it - see attached pic
Not sure since I've not used something like that before - I could use the frustrum to optimize the render and I am trying to find a right balance for the value of Volume Quality on the Mantra ROP as well since I think that will help quite a bit. But the important thing I am trying to figure out is improving the level of detail in the sim while keeping the cache size to around 1-1.5gb per frame.
How are you going to use the frustrum to optimise the render? mantra does that automatically.
The slow part of the simulation is the amount of extra voxels being processed and written to disk, then read back in. That's where you want the optimisiation.
Sorry I meant to cache the sim - I believe there is way to use the camera frustrum to optimize the caching process. I am running some render tests to optimize my render times right now and I think they are pretty OK - now as long as the level of detail in the smoke is proper I should be fine.
If the smoke isn't fast moving you should probably utilize the noise parameters in the pyro shader along with the rest fields.
Always wondered about the noise. Can it look any good/any examples out there? My tests always looked lacking.
Here is a new render with much higher details - compared to the old one. Things I did - increased the disturbance to add smaller details, lowered the division size a bit more (0.05 v 0.03), used VDB to keep the cache size in check (about 20 - 30% lower file size). I might try adding some noise to this to see if it helps but I am pretty satisfied with how it is now.
post-7633-0-77309800-1379582452_thumb.jp
post-7633-0-56304300-1379582460_thumb.jp
Edited by Naeem
