sanostol Posted September 21, 2013 Share Posted September 21, 2013 Hi, I try to get my mind more into dop dataflow, and instantly get some questions, probably not the last ones for example I can create new data with a sopsolver for rbd objects, but the data seems a bit different than other data, for example created with a sopgeometry dop I'm not able to limit the sopsolver to work on a limited set of objects, the data is generated on all objects, and I can not delete the data, I can delete any other data but not this one, but why? Martin deleteData.hipnc Quote Link to comment Share on other sites More sharing options...
sanostol Posted September 24, 2013 Author Share Posted September 24, 2013 (edited) Hi again, solved some problems, but still I can not delete the Data Created by the sopsolver (FracturedGeometry) . Actually I do not need to delete the data container, but I want to get rid of the geometry data inside, as it is not used anymore. the data is created by the /obj/AutoDopNetwork/fractureSolver and I want to delete/empty it with the delete_fracturegeo. If I set the deletedata0 parm to * all data is erased including the FracturedGeometry data leaving empty objects, but if I set it to FracturedGeometry the data is not deleted. Seems not logical. thanks in advance Martin splitrbd.hip Edited September 24, 2013 by sanostol Quote Link to comment Share on other sites More sharing options...
