resonanz Posted September 22, 2013 Share Posted September 22, 2013 I am currently working on some older inlinecpp experiments to become more familiar with the HDK but I run into problems with the latest Houdin builds. Whenever the code compiles I get an error. If I click again on the node to force a recook everything works fine. After some trial and error I think I found the problem. It seems that hcustom is looking for "C:/Program Files/Microsoft SDKs/Windows/v6.0A/Include" what does not exist on my computer. I am not sure why this path is needed because the compiler is somewhere else and I had never problems with it until I installed the latest houdini build. I tried different versions but always got the same error though hcustom builds the dso. In Houdini 12.1 everything compiles fine and as far as I can say this problem did not happen with older Houdini 12.5 builds. So my question now is if this is my mistake and something with my setup went wrong or is it maybe a bug? It´s hard to say for me with my very limited experience in C++ and the HDK. Btw. I am on Windows 7. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
edward Posted September 25, 2013 Share Posted September 25, 2013 Are you using Visual Studio 2008? First test that hcustom on an sample SOP works (eg. SOP_Star.C, and make sure you can create it in Houdini). If that works, then perhaps something needs to be updated in 12.5 since we dropped support for Visual Studio 2005. inlinecpp is extremely hard to do properly on Windows. Quote Link to comment Share on other sites More sharing options...
resonanz Posted September 25, 2013 Author Share Posted September 25, 2013 (edited) Thanks for your reply Edward! Yes, I am on VC 2008. When I use hcustom to build the SOP_Star.c example I get the same error, even thought it compiles. First I thought it might be a problem on my computer but I get the same warning on a different machine. The strange thing is that hcustom worked for me without any problems in older Houdini 12.5 builds. That's what I get when I compile with hcustom. Making 'sop_star.o' and 'C:/Users/X5340/DOCUME~1/houdini12.5/dso\sop_star.dll' from 'sop_star.c'CFLAGS = -TP -Zc:forScope -nologo -DVERSION="12.5.469" -DI386 -DWIN32 -DSWAP_BITFIELDS -D_WIN32_WINNT=0x0501 -DWINVER=0x0501 -DNOMINMAX -D_USE_MATH_DEFINES -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -D_SCL_SECURE_NO_WARNINGS -DBOOST_ALL_NO_LIB -I . -I "E:/Microsoft Visual Studio 9.0/VC/include" -I "C:/Program Files/Microsoft SDKs/Windows/v6.0A/Include" -I "E:/SIDEEF~1/HOUDIN~1.469/toolkit/include" -Ox -MD -EHsc -GR -bigobj -wd4355 -w14996 -DSESI_LITTLE_ENDIAN -DAMD64 -DSIZEOF_VOID_P=8 -DFBX_ENABLED=1 -DOPENCL_ENABLED=1 -DOPENVDB_ENABLED=1 -DMAKING_DSO -Fo"sop_star.o" -LD -link /libpath:"E:/Microsoft Visual Studio 9.0/VC/lib/amd64" /libpath:"C:/Program Files/Microsoft SDKs/Windows/v6.0A/Lib/x64" "E:/SIDEEF~1/HOUDIN~1.469/custom/houdini/dsolib/*.a" "E:/SIDEEF~1/HOUDIN~1.469/custom/houdini/dsolib/*.lib" -out:"C:/Users/X5340/DOCUME~1/houdini12.5/dso/sop_star.dll"Running: hcompile -e sop_star.c"E:\Microsoft Visual Studio 9.0\VC\bin\amd64\cl" -TP sop_star.c -DUT_DSO_TAGINFO='"3262197cbf3141062ab519875732aed33b5ed0e2ca30f9a73be4944b060abfd265f4068fd26220780602ade729c0311c3cabb1109c87a94441033de964f095bc41af51a0ed82588789268d0847ba11fcab4e97a9d5a2d947fba4540b0305b144c471f5509a20ec26a9"' -TP -Zc:forScope -nologo -DVERSION="12.5.469" -DI386 -DWIN32 -DSWAP_BITFIELDS -D_WIN32_WINNT=0x0501 -DWINVER=0x0501 -DNOMINMAX -D_USE_MATH_DEFINES -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -D_SCL_SECURE_NO_WARNINGS -DBOOST_ALL_NO_LIB -I . -I "E:/Microsoft Visual Studio 9.0/VC/include" -I "C:/Program Files/Microsoft SDKs/Windows/v6.0A/Include" -I "E:/SIDEEF~1/HOUDIN~1.469/toolkit/include" -Ox -MD -EHsc -GR -bigobj -wd4355 -w14996 -DSESI_LITTLE_ENDIAN -DAMD64 -DSIZEOF_VOID_P=8 -DFBX_ENABLED=1 -DOPENCL_ENABLED=1 -DOPENVDB_ENABLED=1 -DMAKING_DSO -Fo"sop_star.o" -LD -link /libpath:"E:/Microsoft Visual Studio 9.0/VC/lib/amd64" /libpath:"C:/Program Files/Microsoft SDKs/Windows/v6.0A/Lib/x64" "E:/SIDEEF~1/HOUDIN~1.469/custom/houdini/dsolib/*.a" "E:/SIDEEF~1/HOUDIN~1.469/custom/houdini/dsolib/*.lib" -out:"C:/Users/X5340/DOCUME~1/houdini12.5/dso/sop_star.dll"sop_star.cCreating library sop_star.lib and object sop_star.expSDK: C:\Program Files\Microsoft SDKs\Windows\v6.0AEmbedding manifest 'C:/Users/X5340/DOCUME~1/houdini12.5/dso\sop_star.dll.manifest'into 'C:/Users/X5340/DOCUME~1/houdini12.5/dso\sop_star.dll''[/CODE]And that is the error. It is in German but It means that "C:\Program" is wrongly spelled or could not be found. I think it has something to do with the path to the SDK but for a c++ beginner like me this it just a guess.[CODE]Der Befehl "C:\Program" ist entweder falsch geschrieben oder konnte nicht gefunden werden[/CODE]Many thanks! Edited September 25, 2013 by resonanz Quote Link to comment Share on other sites More sharing options...
edward Posted October 1, 2013 Share Posted October 1, 2013 Try running hcustom with --no-embed-manifest ? Quote Link to comment Share on other sites More sharing options...
resonanz Posted October 5, 2013 Author Share Posted October 5, 2013 On 10/1/2013 at 5:45 PM, edward said: Try running hcustom with --no-embed-manifest ? Thanks Edward that worked! And thanks for the fix in the latest Houdini build! Quote Link to comment Share on other sites More sharing options...
edward Posted October 6, 2013 Share Posted October 6, 2013 Does the latest Houdin build now work for you without the --no-embed-manifest option? Quote Link to comment Share on other sites More sharing options...
resonanz Posted October 8, 2013 Author Share Posted October 8, 2013 On 10/6/2013 at 12:55 PM, edward said: Does the latest Houdin build now work for you without the --no-embed-manifest option? Hi Edward, no, without using --no-embed-manifest i get the same error as before. I guess the reason is still the same. Hcustom is looking for mt.exe in the path "C:\Program Files\Microsoft SDKs\Windows\v6.0A/Bin/x64/" what does not exist on my computer (I did install the SDK on F:\ instead of C:\). But as long as I use the --no-embed-manifest option everything works fine, so thanks again! Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted October 8, 2013 Share Posted October 8, 2013 (edited) Do you have MSVCDir variable set correctly? If not, add it and set its value to point to VC folder. Read this. BTW. You are using Windows SDK or VS 2008? Edited October 8, 2013 by mantragora Quote Link to comment Share on other sites More sharing options...
edward Posted October 11, 2013 Share Posted October 11, 2013 On 10/8/2013 at 6:39 AM, resonanz said: Hcustom is looking for mt.exe in the path "C:\Program Files\Microsoft SDKs\Windows\v6.0A/Bin/x64/" what does not exist on my computer (I did install the SDK on F:\ instead of C:\). Ah, that's a critical piece of information that was missing, that you had installed the Windows SDK into your F:\ drive. Can you find the exact path of where mt.exe is on your F: drive? Then, please log a thorough bug report at sidefx.com. Quote Link to comment Share on other sites More sharing options...
resonanz Posted October 15, 2013 Author Share Posted October 15, 2013 On 10/8/2013 at 7:16 AM, mantragora said: Do you have MSVCDir variable set correctly? If not, add it and set its value to point to VC folder. Read this. BTW. You are using Windows SDK or VS 2008? I am using just the compiler of Windows SDK. On 10/11/2013 at 4:05 AM, edward said: Ah, that's a critical piece of information that was missing, that you had installed the Windows SDK into your F:\ drive. Can you find the exact path of where mt.exe is on your F: drive? Then, please log a thorough bug report at sidefx.com. Yep, you are right. It would have been important to mention i guess. I will look for the path to mt.exe and log the bug today. Quote Link to comment Share on other sites More sharing options...
