maxpayne Posted October 2, 2013 Share Posted October 2, 2013 Hello everyone. A have a problem with sph fluids. My particles merge to ropes instead of become drops. How can I avoid it ? Does Houdini calculate air resistance ? https://vimeo.com/75905315 Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted October 2, 2013 Share Posted October 2, 2013 No, Houdini doesn't calculate the air around the fluid, but this is possible to do. The surface tension is causing the elongated shapes. Reducing the surface tension will cause the fluid to spread out more instead of forming a rope or the resolution could be increased and the fluid would form more natural thin splashes and droplets. Something else to check out is the FLIP solver in Houdini. For most fluid simulations it performs much better (but SPH is still better for some effects). Quote Link to comment Share on other sites More sharing options...
maxpayne Posted October 2, 2013 Author Share Posted October 2, 2013 Thank you Luke. I will follow your advices. Quote Link to comment Share on other sites More sharing options...
maxpayne Posted October 3, 2013 Author Share Posted October 3, 2013 Unfortunately it didn't solve the problem. It's just produced a lot of small ropes. Quote Link to comment Share on other sites More sharing options...
