set $JOB relate to $HIP?
poppy
Is there a way to set $JOB accorsding to $HIP?
Say, I have
Project
/scene
/render
/cache
My $HIP is /Project/scene
Can I set $JOB to $HIP/../ ? I use both Win and Linux, I have to set $JOB by hand everytime I open in diffrent OS.
Thanks!
  • 3 months later...
I've set up qLib and most of the otls work with the exception of the environment
In Windows houdini.env I set HSITE to point toward the site_evironment.py
but I keep getting error on the loading of the file:
OOPS: couldn't find C:/Users/myname/houdini13.0/site_environment.py
Thanks for any help on this.
Edited by motionprojects
  • 1 year later...
I'm digging back this old thread because i have mainly this same problem.
- I'm in the need for a project oriented structure like $JOB (essentially allowing to sort hip files by shots etc)
- I'm rendering with a mixed operating systems (win and osx), so the path needs to be set via an env variable, $HIP works great for this
- I've tried the new $HOUDINI_PATHMAP but this doesn't change $JOB
unfortunatly $JOB is written in the hip file so any attempts to set $JOB in houdini.env fail
I've qlib up and running for a long time but this doesn't change anything because getting my hand on python scripts like the one here (site_environment.py.txtis way out of my head
Does a simple solution exist, telling houdini to doesn't include $JOB path in hip ?
Thanks
hi, Noel,
assuming your project set-up looks somewhat similar to:
Proj($JOB)/
    Renders/
    Scenes/
        shot/
    Cache/
rename  proj_env.py.txt to proj_env.py
proj_env.py.txt
place this file into  your project folder,
save hip into scenes folder
add environment_ql node to your scene file
try moving whole project to a different location, open hip without redefining project(JOB) manually, does the JOB variable update? you should see it in environment_ql node.
Olala that's working !!!
So if i may...
To be perfectly free i would like to move back from the hip file to the actual project folder name without passing through a scene folder, that would be ideal...
I assume in the "for i" statement i would write my project name in place of "scenes"
But how can i tell in python to use that actual projectname found to be the actual $JOB seems? Seems if i just remove the "path.pop()", i'm really close ;-)
But i have to thank you, actually i understand now how that's working at least
I'm setting up now project based otls and taking your first example file i see:
Here you import hda's it's ok and working
OTL_PATTERN = JOB + '/Assets/Otls/*.otl'
But here:
What this part is doing exactly ??
os.environ['HOUDINI_OTLSCAN_PATH'] = JOB + '/Assets/Otls' + ";" + os.environ['HOUDINI_OTLSCAN_PATH']
hda_rescanOTL.rescanOTL()
I'm asking because I don't have a fixed path like in the example but i'm with a path with wilcards and this is not working ...
In my case I have
OTL_PATTERN = JOB + '/*/hda/*.hda'
how can i add that to the scanpath ?
Thanks !
Edited by NNois
if i recall correctly OTL_PATTERN didn't work for me so i manually added all the folders and sub folders with hda's and the forced the refresh. You can walk through the dir tree with:
    def indexPath(directory, ignore_list = []):
        '''index returns list of dirs and subdirs ignoring dirs provided in ignore_list
            like os.listdir, but traverses directory trees'''
        stack = [directory]
        dir_list = []
        while stack:
            directory = stack.pop()
            for obj in os.listdir(directory):
                fullname = os.path.join(directory, obj)
                if os.path.isdir(fullname) and obj not in ignore_list:
                    dir_list.append(fullname)
                if os.path.isdir(fullname) and not os.path.islink(fullname) and obj not in ignore_list:
                    stack.append(fullname)
        return dir_list
