writing a .bgeo through python
freaq
I am working with a very large dataset that is divided into chunks,
and I am getting the data from a file, and then creating the poitns and faces in Houdini.
the points I make through a Python sop, and I want every chunk to be written out as a .bgeo
(as my computer can;t handle all the chunks at once)
so my logic was to do a for loop for every chunk and then use this code:
saveToFile("Y:/points/file_" + string(i)+".bgeo")
i should increment, and the command should work however I keep getting thrown this error:
module has no object saveToFile
I tried hou.saveToFile() but no luck there either...
all help is appreciated!
Guest mantragora
1. And you are executing this on geometry(), right?
pseudocode:
chunk.geometry().saveToFile(somepath)
2. Also, maybe if you use double "\\" in path it will work better?
Edited by mantragora
got it working, apparantly I'm just not thinking straight today xD
it needed to be:
geo.saveToFile("Y:/points/file_" + str(i)+".bgeo")
geo.saveToFile (got to specify what to save in this case geo)
str() instead of string, string() does not exist...
  • 3 years later...
