How to call an environment variable inside an other one ?
HI guys !
in the Aliases and Variables panel (Alt+Shift+A)
i have created the following env var :
SHOT = D:\PROJECT\2013\TOTO\SHOTS\TOTO_0001
now i would like to create the following env var :
RENDER = $SHOT\3DWORK\RENDER
CACHE = $SHOT\3DWORK\CACHE
But it doesn't work ... i also give a try to the following synthax as i am working on windows 7
RENDER = %SHOT%\3DWORK\RENDER
CACHE = %SHOT%\3DWORK\CACHE
just in case i also try to invert the \ to follow the linux synthax so i use the same command but i replace all the \ by /
Both trial doesn't work either ...
So i would like to know if you guys have any idea on what i am doing wrong ?
Thanks for your time !
Cheers
E
Edited by sebkaine
Hi Edward,
Thanks for your support ! well i did try this setup
SHOT = D:/PROJECT/2013/TOTO/SHOTS/TOTO_0001
RENDER = $SHOT/3DWORK/RENDER
I would be curious to know if this work on LINUX just to isolate if the problem is
- OS related
- Houdini related
For the moment i use this layout to write my images
RENDER = 3DWORK/RENDER
$SHOT/$RENDER/myImage.$F4.exr
This works perfectly , But i have to call 2 variable instead of only one , so it would be far more elegant if i could find a way to only use this command :
Cheers
E
Guest mantragora
Windows itself can expand variable in variable, I just tested it and explorer properly opens directory that second variable points too, but in Houdini it doesn't work it so I suppose it's a Houdini thing.
PS. Besides, I'm using similar system for setting up my VisualStudio where I use one variable to set some value in another variable and then VS reads it to correctly setup project.
Edited by mantragora
Many thanks for your help guys !
In fact as windows manage to call env var in env var with %% synthax i was thinking of a Houdini issue ! But i prefer to be sure that i was not forgetting something !
So if i want to use this synthax with the alias and variable panel :
It looks that it's not possible at the moment ! it's not a big deal but it force us to use redundant var in the path instead of only one ...
Thanks again for taking the time to help me ! :)
