yaohaosquall Posted October 23, 2013 Share Posted October 23, 2013 Hi,masters! I want to test sinppet node in volume vop sop,and I try to use "gradient" function to calculate the gradient of the density field,but it turns out an error saying that "Call to undefined function vector gradient...".So,is there any restrction of using vex fuction in sinppet? thanks! Quote Link to comment Share on other sites More sharing options...
magneto Posted October 23, 2013 Share Posted October 23, 2013 I think that means gradient is not available in CVEX if I am not wrong. Might have to ask SESI for an RFE Quote Link to comment Share on other sites More sharing options...
symek Posted October 23, 2013 Share Posted October 23, 2013 gradient() computes its values using shading grid which is available during rendering. Other than that: http://www.sidefx.com/docs/houdini12.5/nodes/sop/volumeanalysis 1 Quote Link to comment Share on other sites More sharing options...
DanBode Posted October 23, 2013 Share Posted October 23, 2013 Maybe you're looking for the volumegradient() function? http://www.sidefx.com/docs/houdini12.5/vex/functions/volumegradient Quote Link to comment Share on other sites More sharing options...
yaohaosquall Posted October 24, 2013 Author Share Posted October 24, 2013 Thanks,Magneto!I don't know much about the differents between CVEX and VEX,gonna have a look on it! Symek,I think you gave me the right answer,Maybe that is why it always works in a shader network.thanks! And DanBode,yeah I'm looking for a method does the same thing as volumegradient() function,but not this one.I'm trying to implement a for loop in vop network that can recursively modify a level set like ln = F(ln-1),so volumegradient vop may not be a appropriate choice because it always references to a sop data that is outside of the vop network which means it can't be modifyed dynamically.I tryed to do it in a foreach node where I can just use a volumegradient to do the right thing but it was not as efficient as i expected, so I'm seeking for a vop loop implementation. thanks anyway! 1 Quote Link to comment Share on other sites More sharing options...
ikarus Posted October 24, 2013 Share Posted October 24, 2013 Unfortunately in order to do any differentiation you need access to nearby voxels which isn't available in an immediate context since voxels(and points) are run independently of each other in vex, this is why vex is fast. Quote Link to comment Share on other sites More sharing options...
