Follyx Posted October 27, 2013 Share Posted October 27, 2013 (edited) Hi, found an old tutorial to teach my son. So there are 2 attricbreate SOPs in it: the left is the new from 12.5; the right from HOU < 12 Both are identical but just the older one work. Or am I blind or something worse? Jesus.... Thanks in advance Cheers attribcreate.hipFetching info... Edited October 27, 2013 by Follyx Quote Link to comment Share on other sites More sharing options...
graham Posted October 27, 2013 Share Posted October 27, 2013 The new AttribCreate doesn't support using the local variable the node creates. In this case you don't even need to. If you just toggle off "Write Values" it will generate the local variable for you without you having to worry about stomping on the existing values. Quote Link to comment Share on other sites More sharing options...
Follyx Posted October 27, 2013 Author Share Posted October 27, 2013 (edited) fine, thank you. Dont know how often I've done that before. Had a knot about the whole quesions from my junior in my head lol Edited October 27, 2013 by Follyx Quote Link to comment Share on other sites More sharing options...
tmdag Posted October 27, 2013 Share Posted October 27, 2013 (edited) they both works for me, even with local variable to create node (which i used to use and use till today without problem). Only problem is that in if statement of point sop, you had dots instead of commas. Works like a charm on 12.5.533 Edited October 27, 2013 by tmdag Quote Link to comment Share on other sites More sharing options...
Follyx Posted October 27, 2013 Author Share Posted October 27, 2013 (edited) wil try it later. thanks Edit: well it works yep, but you dont have a variable mapping Edited October 27, 2013 by Follyx Quote Link to comment Share on other sites More sharing options...
Zach Posted October 28, 2013 Share Posted October 28, 2013 There's always vex... I love using wrangles to set up multiple attributes at once. The following command maps attrib --> ATTRIB: addvariablename("attrib", "ATTRIB"); Quote Link to comment Share on other sites More sharing options...
Follyx Posted October 28, 2013 Author Share Posted October 28, 2013 perfect. Thanks Zach Quote Link to comment Share on other sites More sharing options...
