smooth op wont work on particlefluidsurface
octaviuz
Hi!
houdini newbie here, i use Real Flow a bit so am trying to do meshing in houdini, is pretty good so far, if a bit slow compared to Frost in 3dsmax.
i got a Rf_particle_import -> Particlefluid surface -> group -> smooth
the smooth wont affect the geometery, if i save out the surface as bgeo or obj then groups->smooth works fine
Is there an op i need to have to be able to use smooth?
saving geo out then reloading is a bit cumbersome as i want to tweak settings on particlesurface and also peak...
thanks in advance and excuse my lameness
Octavio
marty:
thanks for the tips, will have a look at VDB surfacing.
dobin:
i am using filtering but it smoothes out bigger details (drop / tendrils) too much, so i have it on low-ish values, the smooth op i am trying to affect higher frequency bumps.
i found out the if i drop a pointjitter op (scale=0) the smooth op works fine! go figure :wacko:
