el_diablo Posted November 1, 2013 Share Posted November 1, 2013 I am trying out H13 and it pretty nice with all the improvements and all. I do have a problem though, that is, I am trying to run a small simulation to test out the FLIP fluids, but it seems to be stuck at the emission object and going nowhere at all. I tried to make the static object collision SDF as clean as possible and it seems to be fine as when its disconnected from the fluids, the fluids behave the same as connected, so the problem seems to be elsewhere. I tried to play around with the separation settings and am still stuck with a non working fluid. Any help is welcome. squ_yellow_v02_r55min.hipnc.zip Quote Link to comment Share on other sites More sharing options...
Guest tar Posted November 1, 2013 Share Posted November 1, 2013 is emitter in the fluid container? Quote Link to comment Share on other sites More sharing options...
el_diablo Posted November 1, 2013 Author Share Posted November 1, 2013 I managed to find/solve problems. First the bounding volume was wrong, second the collision geometry SDF had a inverted sign, which looked good for me in the preview but was was wrong. Anyways works good and looks good. Now I need just to work out the workflows for caching, and which one works best. Quote Link to comment Share on other sites More sharing options...
