Undertaker Posted May 25, 2004 Share Posted May 25, 2004 Hi Everybody, I wonder if it is possible to randomize values of a shader, directly in VOPS or using expressions in the parameter field ... For example, is there a way to randomize the diffuse value of a shader applied on a stamped copy object ? Thanks in advance Julien Quote Link to comment Share on other sites More sharing options...
exel Posted May 25, 2004 Share Posted May 25, 2004 not sure about VOPs, but you could directly manipulate the shader strings in the primitive attributes. Assuming you're assigning the shaders with a Shader SOP, turn off "Use indirect references" on the shader SOP and then take a look at the primitive attributes in the geometry spreadsheet for it. You should see complete shader strings for each primitive, such as: opdef:/Shop/v_plastic amb 1 1 1 diff 1 1 1 spec 1 1 1 rough 0.1 ... etc... You can then copy that string and paste it into an AttributeCreate SOP and assign your shader that way. The cool part about this is that you can substitute all sorts of variables into those strings and have them passed to the shader at render time, such as: opdef:/Shop/v_plastic amb 1 1 1 diff $CR $CG $CB spec 1 1 1 rough `param("myrough",0)` ... etc.. Hopefully that makes sense? Quote Link to comment Share on other sites More sharing options...
Undertaker Posted May 25, 2004 Author Share Posted May 25, 2004 yes, that actually makes sense Thanks for helping ! By the way, I turned off "Use indirect references" and I passed some param's on the shader and it's working well also thanks ! Quote Link to comment Share on other sites More sharing options...
Hazoc Posted October 12, 2006 Share Posted October 12, 2006 Hello. I'm having difficulties on following these instructions. Maybe it's because they're a bit old and Houdini has changed ? I'm also trying to create some variation for stamped objects by using stamp() in a shader color parameter field. It seems like stamping from shops is not allowed or then it need some definitions that I'm not familiar with. Is "geometry spreadsheet" different than spreadsheet ? And where are these "complete shader strings for each primitive, such as: opdef:/Shop/v_plastic amb 1 1 1 diff 1 1 1 spec 1 1 1 rough 0.1" located at ? I've attached a simple scene if someone wants to show a modern way for doing this. Thanks! stamping_with_shaders.zip Quote Link to comment Share on other sites More sharing options...
edward Posted October 13, 2006 Share Posted October 13, 2006 Hello. I'm having difficulties on following these instructions. Maybe it's because they're a bit old and Houdini has changed? No, this method still works and probably is the best way. However, you have several mistakes in your file: 1. You forgot to turn off Use Indirect References on the Shader SOP. 2. You're stamping a value of normalize(rand($PT)). rand($PT) returns a single number between 0 and 1. But normalize() takes a vector. So all this does is produce a value of 1. Each stamping variable is a single number. 3. The operator path that you give to the stamp() expression is incorrect although the Copy SOP is fairly tolerant on this. Is "geometry spreadsheet" different than spreadsheet? Yes. ... where are these "complete shader strings for each primitive ... In the spreadsheet, under Primitives. Extend the vm_surface column. Anyhow, you should be able to see random coloured spheres when you render in the attached file. stamping_with_shaders_fixed.zip Quote Link to comment Share on other sites More sharing options...
Hazoc Posted October 13, 2006 Share Posted October 13, 2006 No, this method still works and probably is the best way. However, you have several mistakes in your file:1. You forgot to turn off Use Indirect References on the Shader SOP. 2. You're stamping a value of normalize(rand($PT)). rand($PT) returns a single number between 0 and 1. But normalize() takes a vector. So all this does is produce a value of 1. Each stamping variable is a single number. 3. The operator path that you give to the stamp() expression is incorrect although the Copy SOP is fairly tolerant on this. Thanks Edward! So the problem was in value randomizing expression. I always forget that normalize() wants a vector. I found those shader strings from spreadsheets primitive section..the very same I checked last night without luck. "Use Indirect References" had been on and off for several tries but forgot to deactivate for my sample scene. About the incorrect stamp() path..what would be the correct one ? This I thought probably to be the main problem.. Quote Link to comment Share on other sites More sharing options...
edward Posted October 14, 2006 Share Posted October 14, 2006 The first argument in your stamp() expression points to a non-existent node. In the file I attached, I've corrected that. Quote Link to comment Share on other sites More sharing options...
