TomRaynor Posted November 13, 2013 Share Posted November 13, 2013 I have been trying to find a solution to this issue for a while and I am hoping someone here has a solution. Currently my user otls folder looks like this: ---->/houdini12.5 ------->/otls ------------>otl1 ------------>otl2 ------------>otl3 ------------>otl4 ------------>otl5 etc... What I would like to have is sub folders within my otls folder so that I can keep the folder ordered and tidy as opposed to just having all of my otls just thrown in the same folder. If I try and put the otls in sub folders within the /houdini12.5/otls/ location, Houdini doesn't pick up the otls at launch time. Is there any way that I can have Houdini pick up these sub folders and the otls within? I was thinking that maybe by putting some code in my 123.py file or something I could get this to work? The kind of structure I am after is: ---->/houdini12.5 ------->/otls ------------>/otlFolder1 -------------------->otl1 -------------------->otl2 ------------>otlFolder2 -------------------->otl3 -------------------->otl4 -------------------->otl5 Thanks very much! Tom Quote Link to comment Share on other sites More sharing options...
graham Posted November 13, 2013 Share Posted November 13, 2013 Houdini will not traverse into subfolders when it loads otls through the standard paths. You would have to explicitly add your subfolders to the path Houdini will look through, or use OPlibraries. http://www.sidefx.com/docs/houdini13.0/assets/install Quote Link to comment Share on other sites More sharing options...
TomRaynor Posted November 13, 2013 Author Share Posted November 13, 2013 OK cool, so I have been checking out OPlibraries. They are quite interesting... I take it you can't get Houdini to use the standard way of searching for otls and also use the OPlibraries way to grab a few extra otls from other places? Basically is it use one method OR the other or can you use a hybrid? I like how Houdini does it by default but just want a few extra otls added on top in other locations... I do like the way you can use wildcards in the OPlibraries file eg. /otl/testFolder/*.otl You would have to explicitly add your subfolders to the path Houdini will look through How exactly would I go about doing this? Don't suppose you could give me a simple code example? Thanks Graham! Quote Link to comment Share on other sites More sharing options...
graham Posted November 13, 2013 Share Posted November 13, 2013 From the link above, you have to configure your HOUDINI_OTLSCAN_PATH to include these directories. By default it isn't set and Houdini just uses all the /otl folders in the regular HOUDINI_PATH. Since it's just a regular path style environment variable, how and where you want to set the path is really up to you. For example on linux you should be able to do something like this in a shell setenv HOUDINI_OTLSCAN_PATH "/home/username/houdini12.5/otls:/home/username/houdini12.5/otls/otlFolder1:/home/username/houdini12.5/otls/otlFolder2:&" Quote Link to comment Share on other sites More sharing options...
Milan Posted November 13, 2013 Share Posted November 13, 2013 (edited) Hey Tom. You can simply add all your paths into houdini.env file under HOUDINI_OTLSCAN_PATH variable ending with the default one HOUDINI_OTLSCAN_PATH= C:/YOUR_PATH/otlFolder1;C:/YOUR_PATH/otlFolder2;$HFS/houdini/otls [/CODE]@Graham: I should probably reload the thread next time before I answer you beat me to it Edited November 13, 2013 by milan Quote Link to comment Share on other sites More sharing options...
TomRaynor Posted November 14, 2013 Author Share Posted November 14, 2013 Interesting stuff... I am trying to use my user houdini.env file but am running into an issue... I want HOUDINI_OTLSCAN_PATH to pick up all of the paths defined by the HOUDINI_PATH environment variable using the @ syntax (as defined by http://www.sidefx.com/docs/houdini13.0/basics/config_env), but also add the otls in a folder such as $HOME/houdini13.0/otls/test I have tried stuff like: HOUDINI_OTLSCAN_PATH = $HOME/houdini13.0/otls/test:@ but it doesn't work. Any ideas? Quote Link to comment Share on other sites More sharing options...
Skybar Posted November 14, 2013 Share Posted November 14, 2013 (edited) I have Qlib installed like this, might help: QLIB=@/otls/qLib HOUDINI_OTLSCAN_PATH=@/otls;$QLIB/base;$QLIB/future;$QLIB/experimental Edited November 14, 2013 by Skybar Quote Link to comment Share on other sites More sharing options...
TomRaynor Posted November 14, 2013 Author Share Posted November 14, 2013 Ahhh... This works. HOUDINI_OTLSCAN_PATH = "$HOME/houdini13.0/otls/test:@/otls" Skybar: I had a look at QLIB once before but decided it was too complicated (or rather I didn't understand what it was doing). I don't suppose you could explain a bit about what QLIB is useful for, how I would set it up and use it and what the two lines of code that you have written above do exactly. Thanks. Quote Link to comment Share on other sites More sharing options...
Skybar Posted November 15, 2013 Share Posted November 15, 2013 (edited) Oh sorry, maybe should have explained. Qlib is a library of OTLs, which basically introduces new nodes or extended versions of existing ones. Quite neat, I don't think they have been updated for H13 yet though. So since it is a bunch of OTLs, that line of code is what I've put in my houdini environment. @ points to C:/users/documents/houdini13.0 (I'm not at my computer atm, so that might not be exactly correct, but you get it). So this will then point to my otls folder: @/otls In my otls folder I then have a folder called qlib, which has its own subfolders to keep it organized. So before I set the OTLSCAN_PATH, I make a variable like so: QLIB=@/otls/qLib Which then points to my qlib folder inside my otls folder. So now I can point to the subfolders quite quickly with that variable: $QLIB/base;$QLIB/future;$QLIB/experimental So two examples of what you where after: OTL1=@/otls OTL2=@/otls/otlFolder2 HOUDINI_OTLSCAN_PATH=$OTL1/otlFolder1;$OTL2;$OTL2/subFolder2 I hope you understand And mind that this is on windows, I have no idea if it is different on Linux/OSX Edited November 15, 2013 by Skybar Quote Link to comment Share on other sites More sharing options...
TomRaynor Posted November 15, 2013 Author Share Posted November 15, 2013 Makes complete sense - Thanks! Now I feel I need to check out the QLIB otls to see if there is anything useful in there Quote Link to comment Share on other sites More sharing options...
jordibares Posted November 18, 2013 Share Posted November 18, 2013 Makes complete sense - Thanks! Now I feel I need to check out the QLIB otls to see if there is anything useful in there he he he… you will certainly like it. ;-) Quote Link to comment Share on other sites More sharing options...
