Digital Asset Parameters
breadbox
I have a VopSop network that I would like to turn into a digital asset. I have promoted all the parameters to the VopSop that the UI will require. Only problem is now I have to put this in a subnet to make a digital asset? and then is there an easy way to re-promote all the vopSop attrs. to the subnet level?
Yes you have to turn it into a subnet (Shift+C), and then to fat promote, you can either select all the parameter of that VOPSOP on the right side of the Edit Type Properties dialog or when that dialog is open quickly Alt+MMB click on parameters. Make sure the prefix options are turned off though. Otherwise you will end up with long parameter names, not labels :)
  • 5 weeks later...
How / where do I turn off prefix options?
