OpenVDB 2.0.0 compiled for H12.1 - sop nodes not visible
I am having quite a bit of troubles accessing SOP OpenVDB nodes from Houdini 12.1 after compiling OpenVDB 2.0.
I manage to compile both the Core Library and Houdini Tooklit.
I successfully installed the library here : $HOME/dev/openvdb/
and $HOME/houdini12.1/dso/
contains all the *.so
10212 -rwxrwxr-x 1 alexp artist 10456537 Nov 20 12:52 SOP_OpenVDB_Advect_Level_Set.so*
856 -rwxrwxr-x 1 alexp artist 876302 Nov 20 12:52 SOP_OpenVDB_Advect_Points.so*
764 -rwxrwxr-x 1 alexp artist 781040 Nov 20 13:05 SOP_OpenVDB_Visualize.so*
356 -rwxrwxr-x 1 alexp artist 364020 Nov 20 13:05 SOP_OpenVDB_Write.so*[/CODE]
At this point , I thought It would be enough to open Houdini and at the Geometry level I should already be able to access all the VDB_* nodes.
For some reason it's not working for me.
I checked the variable HOUDINI_DSO_PATH using 'hconfig -a | grep DSO ' from my linux (Debian) shell and this is the feedback:
[CODE]
HOUDINI_AUDIO_DSO_PATH := '<not defined>'
HOUDINI_DISABLE_IMAGE_DSO := 0
HOUDINI_DSO_ERROR := 0
HOUDINI_DSO_EXCLUDE_PATTERN := '<not defined>'
HOUDINI_DSO_PATH := '<not defined>'
HOUDINI_IMAGE_DSO_PATH := '<not defined[/CODE]
Which (please correct me if i am wrong) means that Houdini should search for dso's in "@/dso_^;@/dso" by default. Which expands to:
1) "$HIP/dso"
2) "$HOME/houdini12.1/dso" (<---this is where my SOP_OpenVDB_* files are)
3) "$HFS/houdini/dso"
What i tried with no luck:
- copy the files to /opt/hfs12.1/houdini/dso
- edit $HOME/houdini12.1/houdini.env
[append] HOUDINI_DSO_PATH= /home/alexp/houdini12.1/dso/
.. and restart houdini from a new shell.
Nothing seems to work.
Does anyone has any clue about why I cannot access OpenVDB 2.0.0 dso's from Houdini 12.1 ?
Have you tried setting HOUDINI_DSO_ERROR to 1 or 2 to see if the dsos are actually being loaded/failing to load?
Done !
Houdini DSO error on '/home/alexp/houdini12.1/dso/SOP_OpenVDB_Transform.so'
libopenvdb_houdini.so: cannot open shared object file: No such file or directory[/CODE]
So I pointed LD_LIBRARY_PATH to the path where I installed OpenVDB library and now it works great !!!
Thank you for your help Graham !!! :)
