Delete DOP object with python
yongbin
This inlinecpp function seems to work where you pass in your hou.DopNode and hou.DopObject:
bool
deleteDopObject(DOP_Node *node, SIM_Data *data)
    DOP_Parent *parent = node->castToDOPParent();
    if (!parent)
        return false
    SIM_Engine  &engine = parent->getNonConstEngine();
    if (data->getDataType() == "SIM_Object")
        SIM_Object *obj = (SIM_Object *)data;
        engine.removeSimulationObject(obj);
        return true;
    return false;
Hi, graham. Thank you for sharing your knowledge!
I've tried import inlinecpp module and inlinecpp.createLibrary, but didn't success. Here is the code I tried.
deleteDopObject = inlinecpp.createLibrary(
name="cpp_del_dopobj",
includes="", # WHAT SHOULD I INCLUDE??
function_sources=["""
bool
if (!parent)
return false
return true;
return false;
[/CODE]
I don't know what module should I include here. Maybe another problem could be also exist. What should I fix here?
Thank you. :)
You basically need to set the includes to include the headers for all the objects that need to be used. Something like this should probably work:
"""#include <DOP/DOP_Parent.h>
#include <DOP/DOP_Node.h>
#include <SIM/SIM_Data.h>
#include <SIM/SIM_Engine.h>
#include <SIM/SIM_Object.h>
  • 1 month later...
Good news with this 13.0.268 release! I checked houdini journal and found this.
Houdini 13.0.268: Added hou.DopSimulation.removeObject and hou.DopRelationship.removeRelationship to remove objects or relationships from a DOP simulation.
