abramov-cg Posted November 22, 2013 Share Posted November 22, 2013 I have a texture sequence from 1 to 150 named (mytexture.0001.tif, mytexture.0002.tif... ...mytexture.0150.tif). I set path in "Texture Map" as: "/home/work/mytexture.$F4.tif" and its work great. But in frame 151 texture disappears. I want to cycle this. Expression $F%150 works fine. But I can't to integrate this to texture path. Quote Link to comment Share on other sites More sharing options...
abramov-cg Posted November 22, 2013 Author Share Posted November 22, 2013 O! I've found the answer: "/home/work/mytexture.`padzero(4,$F%150)`.tif" 3 Quote Link to comment Share on other sites More sharing options...
Rence Posted April 8, 2019 Share Posted April 8, 2019 Thank you so much for this! And thank you for going back and putting the solution to your problem once you solved it Quote Link to comment Share on other sites More sharing options...
