magneto Posted November 24, 2013 Share Posted November 24, 2013 Hi, Same parameter is also in SOP Scalar Field DOP but they are not in the help cards Anyone knows what they actually do? I toggled them but I couldn't see any change in my field data. I assume twod is "Two Dimensional"? Because in Details View it always show as 0, even when I turn on Two Dimensional. Thanks Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted November 24, 2013 Share Posted November 24, 2013 (edited) Same parameter is also in SOP Scalar Field DOP but they are not in the help cards... Two Dimensional: One of the divisions of the voxel grid will be forced to one to create two dimensional field. Plane: If set to two dimensional, this plane determines which axes remain unaffected. Edited November 24, 2013 by mantragora 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted November 24, 2013 Author Share Posted November 24, 2013 (edited) Thanks mantragora. Isn't it like setting Two Dimensional on a Smoke Object? Because then the result is clear. But when I do this for SOP Scalar/Vector Field DOPs, the visualization still stays the same in the viewport (Streamers = off). So I don't know if it's actually doing anything. Maybe those are not hooked? Edited November 24, 2013 by magneto Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted November 24, 2013 Share Posted November 24, 2013 (edited) Look inside SmokeObjectDOP(unlock it) => SmokeConfigureObject(unlock it) => DensityData node. It's a SOP_ScalarFieldDOP. Both of those parameters are exposed outside. Now go figure what you messed in your setup that you can't see change BTW. Press D in your NetworkPane and go to Dependency => Show Local Dependency Links. It will help you to see what other nodes are affected by this node. Edited November 24, 2013 by mantragora 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted November 24, 2013 Author Share Posted November 24, 2013 Thanks I did that but all I see is that is uses it for its Scalar and Vector Field DOPs. My setup is very simple. I just have an Empty Object and a SOP Vector Field that brings in volume data from SOPs. I see the volume as smoke, vectors and streamers accurately. But I don't see any change by changing them in my setup. I assume maybe something else that does the resize is making sure the bounding box is "2d". Gas Resize DOP? Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted November 24, 2013 Share Posted November 24, 2013 Still nothing? Post your setup so people could look what you scratched there Quote Link to comment Share on other sites More sharing options...
magneto Posted November 24, 2013 Author Share Posted November 24, 2013 This is the tutorial I was following: http://www.sidefx.com/index.php?option=com_content&task=view&id=1234&Itemid=262 I found the problem though, it's not me, but the tools. I am very sure this is a UI bug. I had Use SOP Dimensions turned on, which seems to override the Two Dimensional option. Once you turn that off, then it affects the result. So the bug is those options should be disabled if Use SOP Dimensions is turned on. I am really surprised no one complained about this before. It's a very confusing user experience. Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted November 24, 2013 Share Posted November 24, 2013 (edited) http://www.sidefx.co...1234&Itemid=262 Man, you fixed SESI site with your link. I couldn't get into it whole day yesterday. I just came here and BOOM, it works. Just like that. Thanks Edited November 24, 2013 by mantragora 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted November 24, 2013 Author Share Posted November 24, 2013 Hehe yeah, that and timing helps Quote Link to comment Share on other sites More sharing options...
