Emit Flip Fluid Particles From Object Interior
Neo222
Hey guys,
Just having a bit of an issue that is puzzling me. I have noticed that when you emit particle fluids from an object, it only emits from the object surface. I have attached an example image demonstrating the problem I'm having. I have set up custom velocities which will need to be applied to the interior also.
So is there a way emit from an objects interior as well as surface, I have tried a couple of things such as converting the object to a volume and the scattering point but i can't seem to get the particle fluids to source from the points. I have had no luck so far, so any help would be greatly appreciated
Thanks
post-9545-0-04701100-1385376779_thumb.jp
