Cloth Pieces Activation.
advait
Hello Guys,
I am doing a shot in which there are cardboards on the wall in the hallway. I want the pieces of cardboards to fall as if the force is coming towards camera. I was able to do the simulation Fractured object and rigidbodysolver a with point activation. But it doesn't give feel of cardboard. I was wonder if there is any way to activate pieces of cloth using the "activeValue" in dopnet?
I have uploaded a example file for the activation. Please let me know if there is any similar technique to control cloth object.
Thank you.
cardboard_fractured_object_v002.hipnc
You can try to use the attribute "pintoanimation" on all your point. When the value is higher then 0.5, it stick to the sop animation. Using a multisolver with a sop solver and a cloth solver, you could animated your pintoanimation attribute an it should act like the active value node.
  • 3 years later...
