HOM - How to get the button parameter name when the button is pressed.
djbyun
Graham,
I tried to use kwargs['parm_name'] or kwargs['parm'].name(). But they didn't work. The only thing which worked in Python Module was kwargs['type']. Would you mind showing an example code for getting the button parmaters name when I push it?
Thanks.
DJ
kwargs shows lots of information for me when printed from the callback field:
{'node': <hou.ObjNode of type null at /obj/null1>, 'script_value0': '1', 'script_value': '1', 'script_multiparm_index': '-1', '
script_multiparm_nesting': '0', 'script_parm': 'myparm', 'parm': <hou.Parm myparm in /obj/null1>, 'parm_name': 'myparm'}
If you are trying to access this information inside a function in the PythonModule, you would need call the function from the callback field and pass kwargs as the function argument. kwargs inside a PythonModule only gives you the node type information, as you've seen.
button_test.hip
