Editing Glue network in 13
hou_noob
I am a little confused, just stated learning houdini and jumped onto houdini 13 and i am stumped how to edit a glue network.
the network itself is different from houdini 12.5 and i would like to edit the network but am stumped.i would like to partially dissolve the glue network in this test file.
any help/suggestion is much appreciated
glue_network_v2_glue.hipnc
Things are a bit different in H13 since glue networks have been generalized into constraint networks, which can create any type of constraint (e.g. spring). As with Houdini 12.5, you can still attach a SOP Solver to edit the constraint network's geometry, or use the Overwrite with SOP parameter to bring an animated constraint network into the simulation.
