dpap Posted December 9, 2013 Share Posted December 9, 2013 Hi All! I want to create a line from some randomly numbered points (see pic.) In order to use the Add sop the numbering must be ordered by proximity. Sort by Spatial Proximity does not work good! The numbering that it gives is ok at some areas and messed up in others. I cant use the Match topology sop because there isn't any geo I can use for that. So I guess I have to find an alternative way to do it. Any ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted December 9, 2013 Share Posted December 9, 2013 (edited) If the convex shape of the points is good enough you could triangulate and then remove faces. Edited December 9, 2013 by Erik_JE Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted December 9, 2013 Share Posted December 9, 2013 http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=18278&highlight= Quote Link to comment Share on other sites More sharing options...
dpap Posted December 10, 2013 Author Share Posted December 10, 2013 Thank you for you answer guys! However I'm afraid none of your suggestions works because the points are not flat at all... In the file I actually have to create two lines but I guess if I find a way to create one line out of them I can then delete the first set of points and repeat he procedure on the second set. I don't think I can do this without somehow "reinventing" the "Sort by Spatial Locality" ... Line from points.hipnc Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted December 10, 2013 Share Posted December 10, 2013 (edited) There is no easy way of sorting point clouds. I think the only way to do that is to compare points by distance, but this is not always an appropriate solution. Edited December 11, 2013 by Stalkerx777 Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted December 10, 2013 Share Posted December 10, 2013 (edited) You could create something in a sop solver where you specify an initial point and then crawl from that point to the next based on proximity, while creating a sequential attribute at each iteration. Then you'd sort by attribute. I don't think any solution will work for every possible case though. Cheers Edited December 10, 2013 by rafaelfs Quote Link to comment Share on other sites More sharing options...
dpap Posted December 10, 2013 Author Share Posted December 10, 2013 (edited) @Stalkerx777 : " I think the only way to do that is to compare points by distance" ....I totaly agree on that. I thought that the fact that it is not a"chaotic/noisy" Point Cloud but a rather "tidy/ordered" one, with a visible pattern would make things easier. @rafelfs: sounds interesting. maybe I will give your suggestion a try later on. I am trying right now to see if the new "Find Shortest Path" node can help somehow... Edited December 10, 2013 by dpap Quote Link to comment Share on other sites More sharing options...
dpap Posted December 11, 2013 Author Share Posted December 11, 2013 I tried to go another way... I found the nearest point number for each point and tried to make a line using the Foreach sop . I dont know what am I doing wrong here.. Maybe the whole problem is out of my league for the time being... foreach nearest.hipnc Quote Link to comment Share on other sites More sharing options...
hyperforce Posted January 9, 2014 Share Posted January 9, 2014 (edited) I would try to use the attribWrangle node and vex code in combination with a find shortest path node. I won't be able to provide you with an example right away, but I'll try to describe the way to do it: There are 2 ways I can think of to do this:1: This method will work well for the example image of the initial post: By creating a single step - nearest point connection vex script, and then running the find shortest path over that to order your points. Use an AttribWrangle and make it do a point cloud operation to store the points within a certain distance to the current point in an array. Then loop through the array, give every point a temporary variable of VALID = 1. This loops through the array of points found by the current point. Now perform checks for each found point using if statements. If the point number found is the current point being processed set its valid state to 0. If the point found has a point number lower then the current point set it valid state to 0. Then using an if statement, push the point numbers of only the valid points into a new array. Then exit the loop. Outside the loop, find the point number in the array with the lowest and highest value. Now create a primitive using vex (a two vertex polygon line) between the lowest valid point number and the current point number. Do the same with the highest valid point number. If a point does not have any valid targets due to the culling, skip it. Now you will have a system that constructs a maximum of 2 lines per point. This won't be perfect, as it can do branches, but the trick now is to use the start of your curve, (ensure there the shape you just generated is not closed, it has to have a end and start). Use the find shortest path node's distance function to write out the distance from the start point on your curve. Then, delete away the primitives, sort the points by this distance attribute and use an add node to connect everything together. And there you have it, one curve created from your point cloud image. 2: This method is slightly different, and is best suited if you want to create a curve through a curve through a dense point cloud. you can make a cloud-grid using the nearest point connection vex script described above with some changes. But this one is simpler, simply make it do a connection to every point in range (every point in the point cloud array it finds). This will connecting all the points to their nearest neighbors. You can then use the find shortest path node to navigate the grid. You can do this using way points if you do not need it to navigate every point in your cloud, or using a negative cost per point. This last method will do the traveling salesman method, where it attempts to pass through every point in your grid at least once. Edited January 9, 2014 by hyperforce Quote Link to comment Share on other sites More sharing options...
acey195 Posted January 12, 2014 Share Posted January 12, 2014 You can also just make every point connect to every other point. (in seperate primitives) then delete the primitives that are too long, fuse, use a connectivity sop+partition sop to divide it into the inner and outer group. after that you can make both groups form singular primitives by deleting one primitive per shape and using the find shortest path sop to make a single primitive out of it, supplying the start and end point. then you only need to close both primitives, by using an ends sop for instance. Quote Link to comment Share on other sites More sharing options...
grasshopper Posted March 4, 2015 Share Posted March 4, 2015 Hi odForce! Haven't posted on here for years!I had to solve this exact problem on one of the Spider-Man movies where we needed a way for Spidey's webs to hit surfaces without getting twisted. We would project points representing the hit position of each thread in the web's terminating 'Eiffel tower' shape. You get a cloud of points scattered on the surface that isn't necessarily planar. The task is to fit a polygon to the points without getting twists. So I solved this by automatically calculating the best fit plane through the points and the centroid to give me an axis. Then I sorted the points by polar coordinates around this axis. If you then join the points you get an untwisted polygon. Pretty sure it worked every time. 6 Quote Link to comment Share on other sites More sharing options...
scorpes Posted September 20, 2017 Share Posted September 20, 2017 @hyperforce How to make the find shortest path node loop through all the points? Quote Link to comment Share on other sites More sharing options...
acey195 Posted September 20, 2017 Share Posted September 20, 2017 by disconnecting the start and end of your target curve and then create a path from start to end (the long way around) finally reconnect the start and end if needed. alternatively you may want to look at the polypath SOP they added since. Quote Link to comment Share on other sites More sharing options...
Trancor Posted May 20, 2018 Share Posted May 20, 2018 (edited) Hey, old thread but figured I'd chime in, if you are looking for something to read only a random nearby point, try this in a wrangle node--- Its smart enough to detect second input geometry. (Pic 1) Just make sure to hit the `Create Spare Parameters` button on the right of the wrangle node vexpression parameter. Then set `maxLineLength` and `maxFindCount` up to find near by points using `pcfind`. int read=0; if(npoints(1)>0){ read=1; } int pts[]=pcfind(read,"P",v@P,chf("maxLineLength"),chi("maxFindCount")); int l=len(pts); float fl=float(l); int randomConnect=chi("randomConnect"); int rander=pts[int(random(@ptnum*fl+randomConnect)*fl*fl) % l]; vector curPos=attrib(read,"point", "P", rander); int to=addpoint(0,curPos); addprim(0,"polyline",@ptnum,to); Since I'm not sure the end goal, I'll share this line generator I wrote. Connects any found points; supports second input detection. (Pic 2) Same as above, `Create Spare Parameters` Use `Keep Point Count` to not create needless amounts of duplicate points. int drawLine(vector f; vector t){ int base=addpoint(0,f); int to=addpoint(0,t); int line=addprim(0,"polyline",base,to); return line; } //----------------------------- int read=0; if(npoints(1)>0){ read=1; } int maxLines=chi("maxLineCount"); float minLen=chf("minLineLength"); int pts[]=pcfind(read,"P",v@P,chf("maxLineLength"),chi("maxFindCount")); int randomConnect=chi("randomConnect"); int keepPointCount=min(1, max(0,chi("keepPointCount"))); int runner=0; vector curPos; int pt; if(randomConnect == 0){ for(int x=0; x<len(pts);++x){ pt=pts[x]; if(runner > maxLines){ break; } curPos=attrib(read,"point", "P", pt); if(length(curPos-v@P)>minLen && (@ptnum<pt || read)){ if(keepPointCount){ int to=pt; if(read){ to=addpoint(0,curPos); } addprim(0,"polyline",@ptnum,to); }else{ drawLine(v@P,curPos); } runner++; } } }else{ int l=len(pts); float fl=float(l); int rander=pts[int(random(@ptnum*fl+randomConnect)*fl*fl) % l]; curPos=attrib(read,"point", "P", rander); if(keepPointCount){ int to=rander; if(read){ to=addpoint(0,curPos); } addprim(0,"polyline",@ptnum,to); }else{ drawLine(v@P,curPos); } } Edited May 20, 2018 by Trancor Code Fix 3 1 Quote Link to comment Share on other sites More sharing options...
SimoLeo Posted September 28, 2018 Share Posted September 28, 2018 On 21/05/2018 at 9:02 AM, Trancor said: Hey, old thread but figured I'd chime in, if you are looking for something to read only a random nearby point, try this in a wrangle node--- Its smart enough to detect second input geometry. (Pic 1) Just make sure to hit the `Create Spare Parameters` button on the right of the wrangle node vexpression parameter. Then set `maxLineLength` and `maxFindCount` up to find near by points using `pcfind`. int read=0; if(npoints(1)>0){ read=1; } int pts[]=pcfind(read,"P",v@P,chf("maxLineLength"),chi("maxFindCount")); int l=len(pts); float fl=float(l); int randomConnect=chi("randomConnect"); int rander=pts[int(random(@ptnum*fl+randomConnect)*fl*fl) % l]; vector curPos=attrib(read,"point", "P", rander); int to=addpoint(0,curPos); addprim(0,"polyline",@ptnum,to); Since I'm not sure the end goal, I'll share this line generator I wrote. Connects any found points; supports second input detection. (Pic 2) Same as above, `Create Spare Parameters` Use `Keep Point Count` to not create needless amounts of duplicate points. int drawLine(vector f; vector t){ int base=addpoint(0,f); int to=addpoint(0,t); int line=addprim(0,"polyline",base,to); return line; } //----------------------------- int read=0; if(npoints(1)>0){ read=1; } int maxLines=chi("maxLineCount"); float minLen=chf("minLineLength"); int pts[]=pcfind(read,"P",v@P,chf("maxLineLength"),chi("maxFindCount")); int randomConnect=chi("randomConnect"); int keepPointCount=min(1, max(0,chi("keepPointCount"))); int runner=0; vector curPos; int pt; if(randomConnect == 0){ for(int x=0; x<len(pts);++x){ pt=pts[x]; if(runner > maxLines){ break; } curPos=attrib(read,"point", "P", pt); if(length(curPos-v@P)>minLen && (@ptnum<pt || read)){ if(keepPointCount){ int to=pt; if(read){ to=addpoint(0,curPos); } addprim(0,"polyline",@ptnum,to); }else{ drawLine(v@P,curPos); } runner++; } } }else{ int l=len(pts); float fl=float(l); int rander=pts[int(random(@ptnum*fl+randomConnect)*fl*fl) % l]; curPos=attrib(read,"point", "P", rander); if(keepPointCount){ int to=rander; if(read){ to=addpoint(0,curPos); } addprim(0,"polyline",@ptnum,to); }else{ drawLine(v@P,curPos); } } Fantastic thank you so much for sharing this! Quote Link to comment Share on other sites More sharing options...
