randomice particle color on instances
seeing the last particle tutorial on sidefx using H13 plus the halloween instancing tutorial
instancing seems to work a bit different on particles i think.
Im trying to randomize the color of the green channel of all instance particle models.
On the (auto created) location_particle Object node
- I added a instance node and after that
- a material node.
-overrides material use local variables ON
-baseColor and as a color: rand($PT)
does anyone know how to randomize the color?
thnx
