magneto Posted December 14, 2013 Share Posted December 14, 2013 Hi, Anyone knows how to do this? I tried everything but I am not getting a detail attribute using the Set Attribute VOP. Am I missing something or is this possibly a bug? Thanks Quote Link to comment Share on other sites More sharing options...
anim Posted December 14, 2013 Share Posted December 14, 2013 Set Attribute VOP or setattrib() VEX function can't create attributes, they can just set them if they exist, so you need to create the attribute on the geometry before for it to work but if you are using AttribVOP SOP in Detail mode you can just use Bind Export to create detail attribute ( type@attribname for Attrib Wrangle SOP ) 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted December 14, 2013 Author Share Posted December 14, 2013 Thanks anim, I understand it now. I thought Set Attribute VOP the equivalent of using the @attrib syntax. But I guess the equivalent of the @attrib syntax is Bind VOP, right? Then setattrib would be the equivalent of Set Attribute VOP. Quote Link to comment Share on other sites More sharing options...
anim Posted December 14, 2013 Share Posted December 14, 2013 exactly 1 Quote Link to comment Share on other sites More sharing options...
