HQueue Error - HServer unable to start Mantra
I was wondering if any Houdini guru's would be able to help me with a render farm problem we are having.
Each farm client (5 total) has HServer installed, access to the HQueue license server and the shared drive with Houdini distributables.  Additionally we have 100mantra rendering licenses, and 5 batch licenses
When I submit a job and only leave one client enabled (doesn't matter which), the render will be successful.  If I include all clients I receive this error and the job fails.
mantra: Network Error[RWCWRK7004374] HServer was unable to start mantra
mantra: Network Error[RWCWRK7004876] HServer was unable to start mantra
mantra: Network Error[RWCWRK7004560] HServer was unable to start mantra
mantra: Network Error[RWCWRK7004369] HServer was unable to start mantra
mantra: No remote hosts are available for rendering
Does anyone have any ideas to what might be causing this?
Thanks
  • 2 weeks later...
Sorry for the late reply, our studio was closed for the holidays.
we are running all Windows 7 PC's.  When I checked the environment variables they are indeed not set.  Running "hconfig" from the command line tools fails.
Where would I set the env variables for the client machines?  Hqnode.ini or would I need to create a houdini.env file somewhere that points to the host machine?
Here is the contents of my HQnode.ini file, you will notice the job_environment is blank.
[job_environment]
[main]
server = rwcwrk7006750
port = 5000
sharedNetwork.mount = \\rwcwrk7006750\HoudiniShare
Edited by skyros
I managed to get the farm working.  Not sure what was wrong, but it was definitely a config issue.  I just set everything up from scratch again. server, clients and map drives.  For whatever reason it appears that everything is working now.
I really appreciate the help everyone!
