Hqueue server can't start
Hi guys! I can't get my Hqueue server start, it stops after a second automatically, I checked the "errors.log" under "C:\HQueueServer" this is the messages:
Traceback (most recent call last):
  File "C:\HQueueServer\python27\Scripts\paster-script.py", line 8, in <module>
    load_entry_point('PasteScript==1.7.3', 'console_scripts', 'paster')()
  File "C:\HQueueServer\python27\lib\site-packages\pastescript-1.7.3-py2.7.egg\paste\script\command.py", line 84, in run
    invoke(command, command_name, options, args[1:])
  File "C:\HQueueServer\python27\lib\site-packages\pastescript-1.7.3-py2.7.egg\paste\script\command.py", line 123, in invoke
    exit_code = runner.run(args)
  File "C:\HQueueServer\python27\lib\site-packages\pastescript-1.7.3-py2.7.egg\paste\script\command.py", line 218, in run
    result = self.command()
  File "C:\HQueueServer\python27\lib\site-packages\pastescript-1.7.3-py2.7.egg\paste\script\serve.py", line 276, in command
    relative_to=base, global_conf=vars)
  File "C:\HQueueServer\python27\lib\site-packages\pastescript-1.7.3-py2.7.egg\paste\script\serve.py", line 313, in loadapp
    **kw)
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 204, in loadapp
    return loadobj(APP, uri, name=name, **kw)
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 224, in loadobj
    global_conf=global_conf)
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 248, in loadcontext
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 278, in _loadconfig
    return loader.get_context(object_type, name, global_conf)
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 409, in get_context
    section)
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 431, in _context_from_use
    object_type, name=use, global_conf=global_conf)
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 361, in get_context
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 285, in _loadegg
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 561, in get_context
    object_type, name=name)
  File "C:\HQueueServer\python27\lib\site-packages\pastedeploy-1.3.2-py2.7.egg\paste\deploy\loadwsgi.py", line 587, in find_egg_entry_point
    possible.append((entry.load(), protocol, entry.name))
  File "C:\HQueueServer\python27\lib\site-packages\setuptools-0.6c11-py2.7.egg\pkg_resources.py", line 1954, in load
    entry = __import__(self.module_name, globals(),globals(), ['__name__'])
ImportError: DLL load failed: 找不到指定的程序。
    **kw)
    section)
ps: I have another computer installed, and it's running without problem. the two computers have same system and hardware configuration, I read one of the post which got the same error and is from one year ago, said that is related to one of the windows update, but I didn't have that update, but it give me a hint it might still a python related problem rather than Houdini itself. so I wonder if there are indeed some dll can't be imported, how can I fix that? or another windows update messed with python?
  • 1 year later...
